i58_Jess
Feb 13, 2023Aspirant
Select ethernet name on an R7900P Router
When I connect an ethernet cable to this router, it defaults to Netgear93; can I select a different name? If so, how?
i58_Jess
Win11 shows that I am logged into Ethernet to Netgear93. At the same time, I am logged into Wireless SSID i58 (one that I created). What I want to do is log into Ethernet i58 not Netgear93.
I am currently logged into the R7900P.
Feb 13, 2023Guru - Experienced User
Disconnect from the SSID on the router or disable the wifi radio on the laptop.
You should be only connecting to one or the other at separate times.
