i58_Jess
Feb 13, 2023Aspirant
Select ethernet name on an R7900P Router
When I connect an ethernet cable to this router, it defaults to Netgear93; can I select a different name? If so, how?
i58_Jess
Interestingly, I had MS working on the issue, and after much time, they said, "oh, that is assigned by the ISP." Since the Ethernet name is Netgear93 which is the default name in the Router, I assume that the name comes from Netgear not my ISP (Comcast).
microchip8
Feb 13, 2023Master
Windows just fetches the hardware name ID of the router connected to it...
- i58_JessFeb 13, 2023Aspirant
Makes sense, so do you know if the hardware name can be changed?
