i58_Jess
Feb 13, 2023Aspirant
Select ethernet name on an R7900P Router
When I connect an ethernet cable to this router, it defaults to Netgear93; can I select a different name? If so, how?
michaelkenward
Feb 13, 2023Guru - Experienced User
Try this, go into the router and change its name.
In the browser's graphical user interface (GUI):
- Advanced
- Setup
- LAN Setup
- Edit the name
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Change the Router’s Device Name
