EScharnell
Nov 01, 2022Aspirant
Sensi Smart Touch Thermostat provisioning error
We recently bought 3 of these thermostats and when we try to connect to our Netgear R7800 we continue to get a provisioning error after selecting the correct network 2.4GHz and adding the password. ...
Kitsap
Nov 01, 2022Master
The only thing I see on Emersons website is the information below but I am not tech savvy enough to know what it means. Any help would be appreciated.
Your Sensi sends TCP traffic on ports 80, 8091 and UDP traffic on port 8092. To receive over-the-air firmware updates, please make sure UDP traffic to port 8092 (34.233.82.197) and TCP traffic to port 80 (52.55.206.183) is open. This traffic needs to be able to navigate any network firewalls, proxies, or filter devices.
Make sure the device you are using to provision the thermostat with is also connected to the R7800 via the 2.4 GHz band. If you have Smart Connect enabled on your R7800, you may have to disable it to allow separate individual SSID's for the 2.4 GHz and 5 GHz bands.
Smart Connect is under Advanced -> Setup -> Wireless Setup. This is also where you provide separate SSID's for the two frequency bands.
EScharnell
Nov 02, 2022Aspirant
I have a separate SSID for 2.4 and do not enable Smart Switch so I cannot figure out what is going on.
How the connection works is
1. Connect Smartphone to the thermostat wifi.
2. Point thermostat to the 2.4 SSID and enter password
3. After that I get a provisioning error
- FURRYe38Nov 02, 2022Guru - Experienced User
Something to contact the Mfr about for there help and support regarding there product.
- EScharnellNov 02, 2022AspirantI did. Hats where I got that port information but I am assuming the R7800 allows that?
If you need to disable Smart Connect, you'll need a PC and web browser and log into the routers web page and that setting is under Basic tab/Wireless Settings.
