EScharnell
Nov 02, 2022Aspirant
Sensi Smart Touch Thermostat provisioning error
We recently bought 3 of these thermostats and when we try to connect to our Netgear R7800 we continue to get a provisioning error after selecting the correct network 2.4GHz and adding the password. ...
EScharnell
I did. Hats where I got that port information but I am assuming the R7800 allows that?
Nov 02, 2022Guru - Experienced User
If you need to disable Smart Connect, you'll need a PC and web browser and log into the routers web page and that setting is under Basic tab/Wireless Settings.
- EScharnellNov 02, 2022Aspirant
Smart Connect is already disabled. Would a factory reset of the router help at all?
- FURRYe38Nov 02, 2022Guru - Experienced User
What security mode is set on the router?
Might try this, set wifi security to NONE, then see if these devices will connect then. Re-enable WPA2 and AES after checking.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
FURRYe38 wrote:What security mode is set on the router?
I know I have security set to something besides None. Channels in on Auto, for 2.4 and 5 I believe, to set the channel I just select it from the dropdown correct?
