EScharnell
Nov 01, 2022Aspirant
Sensi Smart Touch Thermostat provisioning error
We recently bought 3 of these thermostats and when we try to connect to our Netgear R7800 we continue to get a provisioning error after selecting the correct network 2.4GHz and adding the password. ...
EScharnell
Nov 02, 2022Aspirant
I ensured to turn off mobile data before doing the pairing. I'll try these suggestions and if it doesn't work the thermostats still work on the wall.
EScharnell
Nov 04, 2022Aspirant
I set the channel to 1 and removed security and still got a provisioning error 😞
- KitsapNov 04, 2022Master
EScharnell wrote:I set the channel to 1 and removed security and still got a provisioning error 😞
This points you right back to the response from FURRYe38. The problem is related to the OEM hardware or OEM application or both.
When you are chasing an issue like this and making changes, be sure to power down all of the hardware and start it up cold after the changes. Even though you have made changes to the settings, they often times will not take effect in the hardware until you restart the device. This applies to all of the devices associated with the provisioning process.
- Joe_IDec 07, 2022Aspirant
Did you ever solve this? I am having the same exact issue with Emmerson Sensi ST55 and RAXE500. I had no issue with a different Sensi thermostat with this router last year but can not get it to connect, Provisioning Error.
- EScharnellDec 07, 2022Aspirant
Not yet, Emerson support just today sent me an email response from the issue ticket i opened.
