swilly2012
Aug 10, 2021Tutor
Server certificate cannot be trusted (Nighthawk R7000)
Hi, Hoping someone can help me understand why all of sudden my internet stopped working. I have a Nighthawk AC1900 (R7000) and when I try opening YouTubeTV, HULU, AmazonPrime, etc... I get an erro...
swilly2012
Aug 10, 2021Tutor
I don’t have a modem/gateway. My internet provider is Windstream Kinetic (dish). There is a cable going from the satellite dish to a POE. Then a LAN goes to the router.
I can’t tell what version the router is on. I’m unable to access it through my phone app.
Aug 10, 2021Guru - Experienced User
does it work directly connected to the windstream dish?
- swilly2012Aug 10, 2021TutorWhen I plug the LAN directly in to my laptop, bypassing the router, I get warning… “Ethernet doesn’t have a valid IP configuration “.
- DarrenMAug 10, 2021Sr. NETGEAR Moderator
Do you have a modem of some sort from windstream?
- swilly2012Aug 10, 2021TutorNo modem. I have a cable that runs from the dish to a POE. Then a LAN from the POE to the router. I’ve cycled powered on both multiple times. I unplugged the LAN from the router and plugged in to my laptop. I get the message…”Ethernet doesn’t have a valid IP configuration “.
