swilly2012
Aug 10, 2021Tutor
Server certificate cannot be trusted (Nighthawk R7000)
Hi, Hoping someone can help me understand why all of sudden my internet stopped working. I have a Nighthawk AC1900 (R7000) and when I try opening YouTubeTV, HULU, AmazonPrime, etc... I get an erro...
swilly2012
Aug 10, 2021Tutor
When I plug the LAN directly in to my laptop, bypassing the router, I get warning… “Ethernet doesn’t have a valid IP configuration “.
DarrenM
Aug 10, 2021Sr. NETGEAR Moderator
Do you have a modem of some sort from windstream?
- swilly2012Aug 10, 2021TutorNo modem. I have a cable that runs from the dish to a POE. Then a LAN from the POE to the router. I’ve cycled powered on both multiple times. I unplugged the LAN from the router and plugged in to my laptop. I get the message…”Ethernet doesn’t have a valid IP configuration “.
- plemansAug 10, 2021Guru - Experienced User
so whether its plugged directly from the dish to a pc or dish to router, you get the same issue.
That's what I got from your prior statements.
did you contact windstream kinetic?
- swilly2012Aug 10, 2021TutorI did call Windstream support. They said from what they could tell I should have internet. They are going to send a tech out in the next few days. It seems like I’ve lost the Windstream IP address somehow. My Nighthawk router has always worked great with the Windstream service. I can’t believe it’s something with the router. I have been losing internet off and on the past few weeks. When that happens, I reboot the router and it the internet comes back.
