goromo
Nov 29, 2021Follower
service provider is recommending to see if all settings on modem are up to date due to inconsisten
Internet is going in and out, service provider asking I have moem errors cleared out and make sure settings are up to date. i have reset modem, unplugged and pluged back in. not sure what to do next?...
Nov 29, 2021Guru - Experienced User
get a screen snip of the cable connections page (shows upstream/downstream values) and the event logs.
That helps us check your cable connections.
If you have any splitters, amplifiers, or signal attenuators in the line, i'd recommend removing them.
