BulaBamboo
Jul 14, 2019Aspirant
Set priority for Roku Ultra @ R7800
I am attempting to set my Roku Ultra priority to low per the instructions here: https://kb.netgear.com/24266/How-to-enable-Quality-of-Service-QoS-on-routers-using-the-NETGEAR-web-interface to reduce...
- Jul 14, 2019
BulaBamboo wrote:I am attempting to set my Roku Ultra priority to low per the instructions here: https://kb.netgear.com/24266/How-to-enable-Quality-of-Service-QoS-on-routers-using-the-NETGEAR-web-interface to reduce my data usage.
These instructions are not applicable for your router model (see the information ref. "this applies to").
Further on, QoS does not reduce the amount of data, it just tries to optimize some protocols, ports, and applications data flow.
BulaBamboo wrote:My QoS page doens't have Setup QoS rule > Add Priority Rule option.
The R7800 has like many newer Netgear routers the automatic, database driven QoS in place - no manual priority controls.
BulaBamboo wrote:Also, when I select the Take a Speedtest option, I get 'The Speedtest failed to detect the bandwidth, please check your Internet or try again' when I'm clearly connected.
Probably a bug in your unspecified R7800 firmware version, or your uplink provider does prohibit using certain systems or domains.
schumaku
Jul 14, 2019Guru - Experienced User
- BulaBambooJul 14, 2019Aspirant
Thanks for the thorough reply to all of my queries. Not what I wanted to hear, of course, but thanks.
- RMinNJJul 14, 2019Luminary
?? Turn on QoS and set the speed of your QoS manually to 85 to 95% of your internet bandwidth. Go the sttached devices page and set the prioirity you want for your Roku.
Thanks for replyng. According to schumaku: 'The R7800 has like many newer Netgear routers the automatic, database driven QoS in place - no manual priority controls'. If that's true, I can't set the priority for a specific device like my Roku. When I click on it (Roku) there are no options to change any settings. I see the option to define my bandwidth but I'm not sure I want to reduce everthing.
