BulaBamboo
Jul 14, 2019Aspirant
Set priority for Roku Ultra @ R7800
I am attempting to set my Roku Ultra priority to low per the instructions here: https://kb.netgear.com/24266/How-to-enable-Quality-of-Service-QoS-on-routers-using-the-NETGEAR-web-interface to reduce...
- Jul 14, 2019
BulaBamboo wrote:I am attempting to set my Roku Ultra priority to low per the instructions here: https://kb.netgear.com/24266/How-to-enable-Quality-of-Service-QoS-on-routers-using-the-NETGEAR-web-interface to reduce my data usage.
These instructions are not applicable for your router model (see the information ref. "this applies to").
Further on, QoS does not reduce the amount of data, it just tries to optimize some protocols, ports, and applications data flow.
BulaBamboo wrote:My QoS page doens't have Setup QoS rule > Add Priority Rule option.
The R7800 has like many newer Netgear routers the automatic, database driven QoS in place - no manual priority controls.
BulaBamboo wrote:Also, when I select the Take a Speedtest option, I get 'The Speedtest failed to detect the bandwidth, please check your Internet or try again' when I'm clearly connected.
Probably a bug in your unspecified R7800 firmware version, or your uplink provider does prohibit using certain systems or domains.
RMinNJ
Jul 14, 2019Luminary
..then set it equal to your bandwidth then. You need to have QoS checked on/enabled if you want the priorty buttons to be available on your attached devices page..
BulaBamboo
Done & done. I set the Roku to Low, it was @ Medium but I didn't have QoS enabled. Sounds like I need to binge watch something to test it out. Wish me luck. Thanks!
- michaelkenwardJul 15, 2019Guru - Experienced User
How fast is your internet speed?
- BulaBambooJul 15, 2019Aspirant
30 / 7 Mbps on average.
OK. Slow enough to provide some benefit from QoS.
People sometimes fret about QoS when they have >200 Mbps Internet, which then gets them into territory where QoS slows things down because of its drain on processor power.
