djcabz
Sep 02, 2021Aspirant
Set static DNS Server configuration while in AP Mode
Wondering how one would configure static DNS servers using the below Netgear: Hardware Version R7900P Firmware Version V1.4.1.68_1.3.28 GUI Language Version V1.4.1.66_2.1.46.1 Operation Mode A...
- Sep 02, 2021
You cannot set DNS servers while in AP mode.. In this mode, the router basically acts as a (wireless) switch. Your main router handles all DNS requests
microchip8
Sep 02, 2021Master
djcabz
Sep 10, 2021Aspirant
Thanks microchip8 - accepted your response as the solution.
That said, it does appear as the AP itself is using that legacy configuration of DNS Servers that or the R7900P has a bizarre logic in determining the hostname of connected wireless endpoints...
I know the device is legacy at this point; yet, I do hope they release one more firmware that addresses any security issues AND allows the DNS Server that the R7900P is using itself for lookups to be modified. I'd be happy if they made the configuration accessible only via the cli (hopefully saving time so they don't have to worry about modifications to the GUI
