GAT888
May 04, 2021Aspirant
SET UP KNIGHTHAWK WITHOUT USING SMART PHONE
I DON'T HAVE A SMARTPHONE SO HOW DO I SET UP MY ROUTER?
FIRST, WHAT IS YOUR "KNIGHTHAWK" ROUTER?
Hint: Look for "Model" on the product label.
With that datum in hand, visit http://netgear.com/support , put in
your model number, and look for Documentation. Get the User Manual (at
least). Read. Look for a topic like "Use a Web Browser to Access the
Router"? You do have some kind of computer, right?- microchip8Master
Go to http://routerlogin.net or http://192.168.1.1
Visit the support pages:
Support | NETGEAR
Feed in your model number from the label on it and check the documentation for your hardware.
Begin with the Quick Start/Installation Guide.If you are lucky, it will be one of those that tells you how to use a wired connection to set up the router.
If not, check the manual and look for a section Connect to the Network and Wired Connection
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.Apologies for being a bit vague. You haven't said what device you are trying to set up. They don't all have the same instructions in the documentation, but they mostly work in the same way.
- GAT888Aspirant
Thanks for your suggestions. I'm sorry that I didn't provide enough info for my inquery. However, you did give me enough to work with. Guess I need to finally buy a smart phone.
I have never use a smartphone to set up a router or access point. A wired connection is always more reliable (no wifi to fall over) and forgiving.
