sfossum's avatar
sfossum
Setting IP address in AP mode
I would like to set a static IP address in my R9000.  It is set to AP mode and the Internet option is grayed out.  Is it possible to set a static address in AP mode?
  • sfossum's avatar
    sfossum
    Aug 27, 2020
    Thank you everyone for your help suggestions.  I ended up letting the HP 4650 printer select it's own "static" IP address which was at the upper end of the DHCP pool.  I should not have a problem with that.  If it does get assign to some other device, I'll have a new mystery to solve.  My original problem of printer showing up as offline is resolved.
