sfossum
Aug 20, 2020Aspirant
Setting IP address in AP mode
I would like to set a static IP address in my R9000. It is set to AP mode and the Internet option is grayed out. Is it possible to set a static address in AP mode?
- Aug 27, 2020
Thank you everyone for your help suggestions. I ended up letting the HP 4650 printer select it's own "static" IP address which was at the upper end of the DHCP pool. I should not have a problem with that. If it does get assign to some other device, I'll have a new mystery to solve. My original problem of printer showing up as offline is resolved.
michaelkenward
Aug 22, 2020Guru - Experienced User
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
- sfossumAug 27, 2020Aspirant
