mocajoe
Jul 11, 2022Aspirant
Setting up a static IP with Nighthawk R7960P
Hello! I'm using a Nighthawk R7960P cable router and wish to set up a static IP for one of my laptops. I've searched all over the documentation for this router, looked at web searches, and looked...
- Jul 11, 2022Static IP is set on the device itself. What you're most likely looking for is a DHCP Reserved IP. You can find that in Advanced -> Setup -> LAN Setup
microchip8
Jul 11, 2022Master
mocajoe
YOU ROCK! Thanks for such quick and responsive help! Have a great Monday!
