mocajoe's avatar
mocajoe
Setting up a static IP with Nighthawk R7960P
Hello!   I'm using a Nighthawk R7960P cable router and wish to set up a static IP for one of my laptops. I've searched all over the documentation for this router, looked at web searches, and looked...
  • microchip8's avatar
    Jul 11, 2022
    Static IP is set on the device itself. What you're most likely looking for is a DHCP Reserved IP. You can find that in Advanced -> Setup -> LAN Setup
