chilli_T
Aug 25, 2024Tutor
Setting up fiber bridge between Netgear routers
This is another one of those “setting up a network, need some help, and I’m a bit ignorant” posts. I was referred to the Netgear community from a reddit post. I know this isn't quite the right forum ...
- Aug 25, 2024
Would not be any grounding issue between buildings since LAN doesn't have power running thru it. Also if cabling is done right, would work for CAT6A STP cabling which would be recommended.
Aug 25, 2024Guru - Experienced User
chilli_T
Aug 26, 2024Tutor
Perfect. Thanks for that. It seems like it would be easiest to simply run Cat6 STP cable between the two routers (buried between buildings). So that's just: ISP > router 1 > Cat6 > router 2 (the old AC1900).
I'm hoping to set each router as a separate network. I don't think this should be a problem. Now I just need to choose which router to buy for router 1. If you/anyone has suggestions for ones you particularly like, I'm all ears.
Thanks again!
- FURRYe38Aug 26, 2024Guru - Experienced User
Something to review here and see what may work best for you:
- FURRYe38Oct 21, 2024Guru - Experienced User
Any progress on this?
Thanks again!- chilli_TOct 21, 2024Tutor
I ended up going with your reco, dug a trench, laid some shielded direct burial rated CAT6, PVC conduit to boxes on exterior, and used some RJ45 outlet faceplates for interior connections between routers. Now we have a WiFi network in each building. Works great!
Wanted to make sure to say thanks
Much apreciated! ^_^- FURRYe38Oct 21, 2024Guru - Experienced User
Good to hear. Glad it's working.
Enjoy. 📡
