ADOZ2AD
Feb 29, 2024Aspirant
Setting up login credentials for OPEN VPN
 Hello,  I have a Nighthawk R7000 rooter with a default OS (which I can't change).  I have for several years activated the vpn service with open vpn which works very well.  However, I'd like to increa...
- Mar 01, 2024Needless to say you need to configure the port forwarding on your router to the Syno LAN IP address Voila https://kb.synology.com/fr-fr/DSM/help/VPNCenter/vpn_setup?version=7#b_17 Here a very old OpenVPN Client Syno config example (no guarantee): ========== dev tun
 tls-clientremote XXXXXXXX.synology.me 1194 # The "float" tells OpenVPN to accept authenticated packets from any address,
 # not only the address which was specified in the --remote option.
 # This is useful when you are connecting to a peer which holds a dynamic address
 # such as a dial-in user or DHCP client.
 # (Please refer to the manual of OpenVPN for more information.)#float # If redirect-gateway is enabled, the client will redirect it's
 # default network gateway through the VPN.
 # It means the VPN connection will firstly connect to the VPN Server
 # and then to the internet.
 # (Please refer to the manual of OpenVPN for more information.)#redirect-gateway def1 # dhcp-option DNS: To set primary domain name server address.
 # Repeat this option to set secondary DNS server addresses.#dhcp-option DNS DNS_IP_ADDRESS pull # If you want to connect by Server's IPv6 address, you should use
 # "proto udp6" in UDP mode or "proto tcp6-client" in TCP mode
 proto udpscript-security 2 comp-lzo reneg-sec 0 cipher BF-CBC auth SHA1 auth-user-pass
 <ca>
 -----BEGIN CERTIFICATE-----
 MIIDTTCCAragAwIBAgIJAOQ2welR+cy6MA0GCSqGSIb3DQEBCwUAMIGnMQswCQYD
 xxx-----END CERTIFICATE-----
 </ca>========== Bonne chance! Please note: This was never adopted to the "newer" (modern) OpenVPN standard, however it's still workable:
Kitsap
Feb 29, 2024Master
ADOZ2AD wrote:Hello,
However, I'd like to increase security to connect to my rooter (and therefore to the connected nas server): set up a login and password connection.
Is there a (simple) solution for this type of connection via open vpn?
Is it possible to give rights to certain identifiers or remove them?
I'd like to stop distributing the identification key, but to grant connection rights.Thank you in advance for your reply.
Translated with DeepL.com (free version)
A couple of resource links that could help you find answers.
https://www.snbforums.com/forums/vpn.12/
- michaelkenwardFeb 29, 2024Guru - Experienced UserThe people behind your NAS and its OS may also have useful things to say. - ADOZ2ADMar 01, 2024AspirantI've come to ask for help here because I use the basic netgear os and the basic openvpn vpn option. - michaelkenwardMar 01, 2024Guru - Experienced UserYou referred to "the connected nas server". Most NAS network attached storage (NAS) devices have their own OS. If you mean the DLNA sever on the router, that's something else. Not really NAS.
