ADOZ2AD
Feb 29, 2024Aspirant
Setting up login credentials for OPEN VPN
 Hello,  I have a Nighthawk R7000 rooter with a default OS (which I can't change).  I have for several years activated the vpn service with open vpn which works very well.  However, I'd like to increa...
- Mar 01, 2024Needless to say you need to configure the port forwarding on your router to the Syno LAN IP address Voila https://kb.synology.com/fr-fr/DSM/help/VPNCenter/vpn_setup?version=7#b_17 Here a very old OpenVPN Client Syno config example (no guarantee): ========== dev tun
 tls-clientremote XXXXXXXX.synology.me 1194 # The "float" tells OpenVPN to accept authenticated packets from any address,
 # not only the address which was specified in the --remote option.
 # This is useful when you are connecting to a peer which holds a dynamic address
 # such as a dial-in user or DHCP client.
 # (Please refer to the manual of OpenVPN for more information.)#float # If redirect-gateway is enabled, the client will redirect it's
 # default network gateway through the VPN.
 # It means the VPN connection will firstly connect to the VPN Server
 # and then to the internet.
 # (Please refer to the manual of OpenVPN for more information.)#redirect-gateway def1 # dhcp-option DNS: To set primary domain name server address.
 # Repeat this option to set secondary DNS server addresses.#dhcp-option DNS DNS_IP_ADDRESS pull # If you want to connect by Server's IPv6 address, you should use
 # "proto udp6" in UDP mode or "proto tcp6-client" in TCP mode
 proto udpscript-security 2 comp-lzo reneg-sec 0 cipher BF-CBC auth SHA1 auth-user-pass
 <ca>
 -----BEGIN CERTIFICATE-----
 MIIDTTCCAragAwIBAgIJAOQ2welR+cy6MA0GCSqGSIb3DQEBCwUAMIGnMQswCQYD
 xxx-----END CERTIFICATE-----
 </ca>========== Bonne chance! Please note: This was never adopted to the "newer" (modern) OpenVPN standard, however it's still workable:
ADOZ2AD
Mar 01, 2024Aspirant
o! that would be perfect!
I use a Synology nas server!
Do you have a link to the procedure?
Thanks in advance
schumaku
Mar 01, 2024Guru - Experienced User
dev tun
tls-client
#float
pull
proto udp
script-security 2
comp-lzo
reneg-sec 0
cipher BF-CBC
auth SHA1
auth-user-pass
<ca>
xxx
</ca>
Bonne chance!
