karlo88
Apr 30, 2021Tutor
Setting up Port Triggering for Port Forwarding
My RangeMax recently failed and I replaced it with a ProSafe FVS318N. I understand the former is for home use and the latter is for business. On the RangeMax, I had Port Forwarding set up for a vid...
karlo88
Apr 30, 2021Tutor
The RangeMax setup page is attached. One can choose between Port Forwarding and Port Triggering
The ProSafe is only for Port Triggering. There is no option on that page, nor another page, for Port Forwarding
I am seeking someone to help me setup the ProSafe step by step to accomplish Port Forwarding. I am guessing that it has something to do with associating certain LAN IP addresses to ports and opening those ports to those IP addresses.
karlo88
Apr 30, 2021Tutor
Here is what the ProSafe setup page looks like
- antinodeApr 30, 2021Guru
> page, nor another page, for Port ForwardingSo, your claim is that the FVS318N Reference Manual is lying?
Your picture shows Security > Port Triggering, which is not the right
page. As the Reference Manual says, "1. Select Security > Firewall.
[...]" (page 140).> [...] Get the Reference Manual (at least). Read. Look for "Inbound
> Rules (Port Forwarding)"?Did you? "Chapter 5 Firewall Protection" (page 129), "Inbound
Rules (Port Forwarding)" (page 134), "Configure LAN WAN Rules" (page
139), "Create LAN WAN Inbound Service Rules" (page 144), ...The FVS318N is not only obsolete, it's also rather flexible/capable,
which means that it can be more difficult to configure than some simpler
device. As previously suggested, reading the FVS318N Reference Manual
can help. I have better ways to spend my time than reading the FVS318N
Reference Manual to you.- karlo88May 01, 2021TutorThe person who setup the RangeMax is no longer here. I am looking at its settings with no understanding of it. Based on what I read now, my understanding is that the RangeMax’s port forwarding can be accomplished on the ProSafe by configuring Port Triggering, and, after that, configure Firewall outbound rules and Firewall inbound rules. Or, do I only need to configure Firewall outbound and Firewall inbound?
Edit: Considering again, maybe I only need to setup inbound rules, because outbound traffic is, by default, unrestricted? And I don’t need to worry about Port Triggering settings at all?- antinodeMay 01, 2021Guru
> its settings with no understanding of it. [...]Then you might need to read the FVS318N Reference Manual.
> [...] my understanding is that the RangeMax's port forwarding can be
> do I only need to configure Firewall outbound and Firewall inbound?If I wanted port triggering, then I'd read the part of the manual
which talks about port triggering. If I wanted port forwarding, then
I'd read the part of the manual which talks about port forwarding.
Either way, you'd be dealing with "inbound" connections, not "outbound".> Edit: Considering again, maybe I only need to setup inbound rules,
> because outbound traffic is, by default, unrestricted? And I don't need
> to worry about Port Triggering settings at all?Sounds right to me.
