Jovanny55
Apr 08, 2020Tutor
Setting up second router
So I have a xr500 and I want to use my old R6300 to extend my network. I set a static IP for my R6300 on the XR500 (not sure if i had to do anything on the R6300 after the static IP was setup on the X...
- Apr 09, 2020
Jovanny55 wrote:
...I thought cascading might be better.What does that mean?
The solution is, as suggested, to put the R6300 into AP mode.
All the other stuff in your first message is a diversion.
Jovanny55
Apr 08, 2020Tutor
I click on the check box that said “enable AP mode.” The speeds weren’t fast for gaming so I thought cascading might be better. But i think I’ll just talk to netgear’s customer support since they may be less of a pretentious **bleep** than yourself
michaelkenward
Apr 09, 2020Guru - Experienced User
- Jovanny55Apr 09, 2020TutorThanks. Quick question, when I put the router into AP mode, are my LAN ports supposed to stop working? While in AP mode, my router isn’t letting me connect to it by wire, only wireless WiFi is working on the router which is in AP mode?
- michaelkenwardApr 09, 2020Guru - Experienced User
Jovanny55 wrote:
Quick question, when I put the router into AP mode, are my LAN ports supposed to stop working?No. They should work.
