Otacon1337
Jan 01, 2022Aspirant
Setting up VLANs with GS108PEv3 Switch and Nighthawk R9000 not working
I have a NETGEAR Nighthawk R9000 router and a NETGEAR GS108PEv3 8 port gigabit switch. My goal is to partition my network with VLANs for better efficiency and security. I have been reading KB arti...
schumaku
Jan 02, 2022Guru - Experienced User
Simple: The R9000 does (like any other Netgear consumer routers) not support any VLAN multi-network configuration on the LAN side.
The VLAN/Bridge group does allow handling some dedicated VLAN on the WAN/Internet side (like IPTV typically) over to the LAN, eg. bridging to defined port(s).
-Kurt
Otacon1337
Jan 02, 2022Aspirant
Understood, thanks. It appears that I will need to buy a router/firewall, capable of 802.1q, for my network stack to accomplish my objective.
