RugbyDad
May 14, 2016Aspirant
Setting up VPN for Nighthawk X6 R7900 - Apple Environment
I have the Netgear X6 R7900 (Firmware: V1.0.1.4_10.0.12) for our home envrionment. We are essentially an all Apple environment with Macbook Air, Macbook, Macbook Pro's, iPad's, and iPhones (and iPod...
- May 16, 2016
It only means iPhones, iPads and Android phones/tablets. OpenVPN should work with your Mac OS PC
storm1985
May 16, 2016Prodigy
- RugbyDadMay 16, 2016Aspirant
Thank you for the response. That is helpful. Has there been any indication as to when iOS and Android platforms will be supported?
- storm1985May 16, 2016Prodigy
Once a new firmware will be release to support iOS and Android it will be indicated on the release notes.
Just watch out for the new firmware. There will also be a notification on the GUI once new fw upgrade is available.
You can see the release notes here or on the GUI as well.
Great! And thank you for the information.
