RugbyDad
May 14, 2016Aspirant
Setting up VPN for Nighthawk X6 R7900 - Apple Environment
I have the Netgear X6 R7900 (Firmware: V1.0.1.4_10.0.12) for our home envrionment. We are essentially an all Apple environment with Macbook Air, Macbook, Macbook Pro's, iPad's, and iPhones (and iPod...
- May 16, 2016
It only means iPhones, iPads and Android phones/tablets. OpenVPN should work with your Mac OS PC
RugbyDad
May 16, 2016Aspirant
Thank you for the response. That is helpful. Has there been any indication as to when iOS and Android platforms will be supported?
storm1985
May 16, 2016Prodigy
Once a new firmware will be release to support iOS and Android it will be indicated on the release notes.
Just watch out for the new firmware. There will also be a notification on the GUI once new fw upgrade is available.
You can see the release notes here or on the GUI as well.
- RugbyDadMay 16, 2016Aspirant
Great! And thank you for the information.
