glung's avatar
glung
Setting up wireless bridge
Hello:   I have a R7800 setup to connect to the internet running 5GHz only; then I have a R7500 which I wanted to setup as bridge.  I went through the setup on R7500 and after I hit Apply on the br...
  • glung's avatar
    glung
    Aug 28, 2019
    After a few hours of resetting and playing with different settings, I finally got it to work..  turned out I got the R7500 to use the same wifi channel as the R7800 and it went through!
    Thanks for your input.
