Jaunty1
Apr 28, 2017Aspirant
Settings File Compatibility
I keep my firmware up-to-date and always save a copy of the latest settings file. Is this file compatible with some or all newer Nighthawk models? In other words, can it be used to initialize a newer...
Apr 30, 2017Guru - Experienced User
Just FYI, all router mfrs do this. Good Luck.
Jaunty1
Apr 30, 2017Aspirant
If that's the case, they're all run by idiots.
- michaelkenwardApr 30, 2017Guru - Experienced User
Jaunty1 wrote:If that's the case, they're all run by idiots.
Or by people who prefer an easy life and do not feel the need to rewrite technological history. If it was an easy move, it would have happened by now.
By the way, you are not the first engineering genius to be frustrated by these configuration files. This issue comes up pretty often, most recently in a discussion with a slightly more reasonable and constructive approach.
One idea was that users could export their configuration to an xml file. It might not be loadable into another device but at least users would be able to read it and retrieve their own settings for manual insertion into a new device. No more need to make a stack of screen grabs whenever you tweak the settings.
- Jaunty1Apr 30, 2017Aspirant
NETGEAR Genie is a program. Programs routinely execute subroutines when opened, closed, and data/settings change. It is an INCREDIBLY SIMPLE matter to save settings in a secure ASCII (or XML) file and make it available to the user for recovery purposes.
Based on your input, I'm withdrawing my "idiots" accusation and replacing it with "lazy, irresponsible, foolish idiots".
- FURRYe38Apr 30, 2017Guru - Experienced User
Well I don't work for NG so NG would have to see if that would be a idea they want to take up. Based on what they and most other MFrs so, Good luck in waiting for what you think would work for all modem routers. LOL.
Good Luck.
