harveybirdman
Dec 03, 2022Aspirant
Setup for connecting two routers (R7000 & XR1000)
Hi, I'm super confused on how I should be properly setting up a second router. I have my modem, two routers (R7000 & XR1000) and PC all wired. Ideally I'd like both routers to support the same wirele...
- Dec 03, 2022
try setting the XR for AP mode if the R7000 is the primary router:
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
Though I would set the XR as primary and then configure the R7000 for AP mode.
Far appart channels are needed in between the XR and R series routers for wifi settings.
Kitsap
Dec 03, 2022Master
For your Ethernet connections. Output of your modem should connect to the WAN input of your primary router. One of the primary router output ports should connect to the WAN input port on your other router configured as a wired access point.
Don't know why you have your XR1000 connected downstream of your R7000. I second FURRYe38 recommendation to set your XR1000 as the primary router connected to your modem and configure your R7000 as an access point.
