harveybirdman
Dec 03, 2022Aspirant
Setup for connecting two routers (R7000 & XR1000)
Hi, I'm super confused on how I should be properly setting up a second router. I have my modem, two routers (R7000 & XR1000) and PC all wired. Ideally I'd like both routers to support the same wirele...
- Dec 03, 2022
try setting the XR for AP mode if the R7000 is the primary router:
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
Though I would set the XR as primary and then configure the R7000 for AP mode.
Far appart channels are needed in between the XR and R series routers for wifi settings.
Dec 03, 2022Guru - Experienced User
harveybirdman
Dec 04, 2022Aspirant
Thanks FURRYe38 and Kitsap . I've swapped around the R7000 and XR1000 and it seems to be working.
Only remaining problem is how do I access the dashboard of the R7000 now? If I go to routerlogin.net it brings me to the XR1000 dashboard. I tried unplugging everything and plugging the R7000 direct to the PC and then going to routerlogin.net/192.168.1.1 but it wouldn't load.
- FURRYe38Dec 04, 2022Guru - Experienced User
IF you put the R7000 in AP mode, look at the XRs connected devices list and see if the R7000 appears there, if so, look at the IP address. Use this IP address to access the R7000 in AP mode. One could set a static IP address of 192.168.#.70 on the R7000 so you'd know always how to access the R7000 while in AP mode. I recommend setting a Default DHCP IP address pool range of .100 to .200 on the XR router as well.
- harveybirdmanDec 06, 2022Aspirant
Thanks, so far so good. I set a static IP on the R7000 and then reserved that on the XR1000. I can now access the two separate admin pages on their own IPs.
For the Wifi, I set the XR1000 to channel 3 and the R7000 to channel 11. Right now they have different SSIDs. Should I make them the same name or better to keep different?
- KitsapDec 06, 2022Master
harveybirdman wrote:Thanks, so far so good. I set a static IP on the R7000 and then reserved that on the XR1000. I can now access the two separate admin pages on their own IPs.
Your progress is duly noted. 😊 Thanks for sharing back.
Do you have a lot of close in Wi-Fi neighbors? If not, you could go to channel 1 on the XR1000 Wi-Fi for 2.4 GHz. If yes, channel 6 would also work.
The SSID naming is mostly personal preference. I do not do a lot of roaming. When I am in one section of the house I like to connect to a specific Wi-Fi of my choosing. Thus the different names.
How have you handled the SSID on the 5 GHz band?
