scothouse
Feb 27, 2016Aspirant
Setup R7000 in Bridge Mode
I am the new owner of two Nighthawk R7000 Routers. One I have configured as a router - it's connected to an Arris Surfboard 6190 cable modem and working flawlessly with both wired and wirelsss clients that are connected.
I want to setup the other Nighthawk in bridge mode right next the AV equipment that I use principally for streaming. I setup the second Nighthawk and configured in bridge mode according to these instructions. I have ethernet running between the Nighthawk router upstaris in the office and the Nighthawk bridge in the AV room. I expected that the two devices would connect via the ethernet cable (which is connected via a LAN port out on the router and the WAN port in on the bridge), but that's not what is happening - the bridge is showing as connected to the router via wireless. Further, I have devices (e.,g an Apple TV) connected via ethernet to the bridge, but on the attached devices map of the router, these devices are showing a wireless, not a wired connection.
Where did I go wrong in my setup? Thanks in adcvance!
-Scot
How to I perform a factory reset?
- Retired_Member
You want AP MODE! or use a switch if streaming devices have LAN ports.
The device showing up as wifi is because it's using wifi (bridge ) to connect to main router. MAKE SENSE???
Thanks for the reply - but no, I'm not tracking with.
Shouldn't, if the two devices are connected via ethernet, connect that way (rarher than wireless)?
The goal is to get greater bandwidth to AV devices that are way downsteam.
- Retired_Member
The bridge is a wireless connection,( Look at the picture in the link you posted) Why because the bridge is connected via WIFI to the main router. Plugging in a Cat xx cable means nothing BECAUSE you're using bridge when you SHOULD be using AP Mode.
USE AP MODE and all your concerns will be addressed.
Okay, so I've taken you're advice and connected my Smart TV and Apple TV (streaming devices) to a switch that is connected via ethernet directly to the router. As expected - excellent results.
So, am I correct in saying that the Nighthawk 7000 in bridge mode needed be connected wirelessly to the router. Does ot work to somehow boost the wireless signal from where it is placed? That is the secondary function I am wanting to achieve with the bridge mode function.
I understand your point about AP - but I don't won't to project anohter network. I simply want:
- One and strong and consistent wifi network throughout my 2,500 + old Victorian home (two stories - the main router is upstrairs);
- Optimal throughput to my streaming devices setup on the first floor.'
Thanks again for your input!
-Scot
- Retired_Member
You still want AP MODE!!
Use same SSID's and securityOn 2nd thought do some research on the benefits of using AP Mode especially in large homes. After several days of thinking about come back with any questions.
Trust Me you want AP MODE.
Hi Searay - thanks so much for your input - much appreciated.
I totally get where you are coming from with AP mode. But I only want one network through the entire house - that's why I was wanting to use bridge mode. To my understanding, plesase correct If I'm wrong, using AP would require a second network. In other words, and I think as you have noted, I cannot use AP and the same network as my router is projecting.
I'm coming from an Apple setup where I had one router and one bridge tied together by ethernet but both projecting the same network.
Thanks again for your help.
- Yup. Make sure to use different Wi-Fi channels.
- Retired_Member
You're Welcome and Good Luck with it!
