scothouse
Feb 27, 2016Aspirant
Setup R7000 in Bridge Mode
I am the new owner of two Nighthawk R7000 Routers. One I have configured as a router - it's connected to an Arris Surfboard 6190 cable modem and working flawlessly with both wired and wirelsss client...
- Retired_MemberFeb 28, 2016
I'll try this one last time.
Ever been to a hotel?
They use AP's some hotels use dozens of them.
They also have one SSID to cover ALL the Guest rooms.
You're over thinking this instead of taking my suggestions.
Use AP mode
use same SSID on each band 2.4 xxx & 5G yyyy
Use different channels 2.4 1,6 or 11 5g 48 or 161
Use same security on all
Been doing this for 5 years IT DOES WORK.
TheEther
Feb 28, 2016Guru
searay is right. Netgear's bridge mode uses dedicated Wi-Fi to connect to the main router. Only wired clients are allowed.
You want AP Mode, which uses Ethernet (or Powerline) to connect to the main router. Both wired and wireless clients are allowed. It does not create a second IP network.
scothouse
Feb 28, 2016Aspirant
Beautiful - so if I use AP mode, and configure both the main router and attached AP to project the same SSID, I'm golden? Thanks!
