Whoisd3v's avatar
Whoisd3v
Several Questions..
Basically I have this issue where my signal for gaming is weak because our family modem is a floor below me. So I've been looking into finding anything that'll make that signal stronger: i.e. an ext...
  • Whoisd3v's avatar
    Whoisd3v
    Jul 01, 2019
    That’s exactly what it was, schumaku. I had my ethernet plugged into the LAN the entire time. Plugged it into one of the ethernet ports and viola! Worked like a charm. Thanks for that, now I know for sure how bridge mode works in the future.
    Speaking of future, I’ll be moving pretty soon. I’ll probably be switching ISPs, which would probably require that I’ll need to edit my bridge settings towards a newer router. How would I go about taking it out of bridge mode if that’s the case?
