Blackwith
Jul 26, 2021Aspirant
SFP+ module 10Gbase-T compatible
Hello, I'm looking for module 10Gbase-T compatible with my XR700. I already saw the list but 10G Copper is not listed : https://kb.netgear.com/31408/What-SFP-modules-are-compatible-with-Nighthawk-...
schumaku
Jul 26, 2021Guru - Experienced User
Start here: What SFP+ modules are compatible with Nighthawk X10 R9000, R8900 and Nighthawk Pro Gaming XR700 routers? Virtually all industry standard modules are workable, there is no limitation. Keep in mind the power available on the SFP+ port is limited, there is not enough power to establish a full IEEE 10GbE 100 meters link, the reach of a 10 GbE link is limited (~30...35 meters typically) check your selected module FMI..
Using a search engine "site:community.netgear.com r9000 sfp+ rj45" does show various similar requests and some modeule types.
Blackwith
Jul 28, 2021Aspirant
I just bought 10Gb SFP+ RJ45 Module - 10Gbase-T on Amazon : https://www.amazon.fr/dp/B01M8O3MAL?ref=ppx_pop_mob_ap_share
It's working perfectly !
Thanks for your answer. My problem was having an explicite answer about the XR700 router and not another netgear router.
