Carrera911fan
Mar 25, 2017Aspirant
Sharp Aquos TV doesn't find Netgear wifi router
The new Nighthawk X8 AC5300 wifi router is installed and all our devices connect successfully, with the exception of our Sharp Aquos TV. The TV doesn't find the wifi router - our home wifi network i...
- Apr 01, 2017
Thank you for the suggestions. Because all of our other devicies work fine with our wifi, we decided it must be a problem with the TV, so we went with a new Apple TV rather than hassling with TV repair.
Thus concludes the saga of my Sharp TV / Netgear wifi dilemma. :)
Mar 29, 2017Guru - Experienced User
Try this, disable security on the WiFi temporarily to see if the TV can see the wifi SSID name. Disable on 2.4Ghz first. If the TV does not see the SSID name and or can not connect to the SSID name while security is OPEN, then there probably is something wrong with the TV.
Re-enable WPA2 security after testing.
Need to find out if your TV supports 5Ghz wifi or not. Contact the Mfr.
Does the TV have a wired LAN network cable port? If it does, try connecting the TV to the router that way.
Carrera911fan
Apr 01, 2017Aspirant
- FURRYe38Apr 03, 2017Guru - Experienced User
Cheers.
