etonsrawi
Dec 27, 2022Follower
Should I upgrade to a wifi 6 router or just get a new wifi 5 router?
I have had a Netgear Nighthawk R7000 Smart WiFi Router (AC1900) for the past five years and it's been great, but it's starting to show its age. I've "fixed" it many times but I'm ready to get a new...
Dec 27, 2022Guru - Experienced User
How big is the home and how many stories in it?
Mesh systems work great in buildings that needed the added coverage but a flagship router is going to be faster if the home is small enough it doesn't need the mesh solution.
Whats your budget? Its pointless to recommend a device out of your budget.
Do you have any AX devices? Are you planning on upgrading?
