jusjohn55's avatar
jusjohn55
Should R7000 be in router mode or AP mode?
I have been trying for months to get a router that gives me a proper signal since the other routers I get will drop signals. I am not even that far from the router, I am the floor right above it. I g...
  • michaelkenward's avatar
    Aug 16, 2019
    jusjohn55 wrote:
    I got the R7000 and whenever I try to go into AP mode I get that amber light for the wifi. Meaning I am getting no connection.
    What are you trying to do with the R7000? Wire it into the C7000?
    If the C7000 is acting as a modem/router then it is easiest to use the R7000 as a wireless access point. If not you risk the dreaded double-NAT disease.
    Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
    This explains some of the other drawbacks.
    What is Double NAT? | Answer | NETGEAR Support
    Remember, when messing around with the mode of the modem and/or router it helps to restart the whole network in the correct order.
    • Turn off and unplug modem.
    • Turn off router and computers.
    • Plug in and turn on modem. Wait 2 minutes for it to connect.
    • Turn on the router and wait 2 minutes for it connect.
    • Turn on computers and rest of network.
