OneJoe2
Jun 13, 2020Tutor
Should the R8000 UI see devices connected via a GS308 switch?
 In the supplied user interface, on the Basic tab,  "attached devices/wired devices" area,   should I be seeing any info at all (like status, IP, MAC address) for devices on a connected GS308v2 or is ...
- Jun 13, 2020You should see all devices connected to the switch
microchip8
Jun 13, 2020Master
- OneJoe2Jun 13, 2020TutorThank you! - michaelkenwardJun 14, 2020Guru - Experienced UserAs long as the switch as after the router. - OneJoe2Jun 15, 2020TutorAfter the router .. yes. Thanks!
