OneJoe2
Jun 13, 2020Tutor
Should the R8000 UI see devices connected via a GS308 switch?
In the supplied user interface, on the Basic tab, "attached devices/wired devices" area, should I be seeing any info at all (like status, IP, MAC address) for devices on a connected GS308v2 or is ...
- Jun 13, 2020
You should see all devices connected to the switch
microchip8
Jun 13, 2020Master
OneJoe2
Jun 13, 2020Tutor
Thank you!
- michaelkenwardJun 14, 2020Guru - Experienced User
As long as the switch as after the router.
- OneJoe2Jun 15, 2020TutorAfter the router .. yes. Thanks!
- OneJoe2Jun 16, 2020Tutor
cable modem -> R8000 router -> GS308 switch -> devices
This is considered after the router, yes?
I replaced the switch with a new GS308v3, changed to new cables and still can't "see" the devices on the switch.
All devices work fine if I connect them directly to the router but not on the (new) switch.
I assume it doesn't matter which of the 4 ports I use to connect the switch to the router and that it's okay to be using the other 3 ports for other devices simultaneously
And that it doesn't matter which port on the switch that I use to connect to the router?
Either my expectatons are wrong, the router is broken or my connections are wrong?
- antinodeJun 16, 2020Guru
I don't know what "before" or "after" a router means. It's an
ambiguous nonsense concept. I do know what the WAN side and the LAN
side of a router mean.If a port on your switch is connected to a LAN Ethernet port on the
router, then things should work properly.Now, let's move on to actual facts.
> [...] still can't "see" the devices on the switch.
What are these (unspecified) "devices"?
Is your complaint that these (mystery) devices do not _work_ if you
connect them to the switch, or that they work, but don't appear in an
Attached Devices report on the router, or what, exactly?> I assume it doesn't matter which of the 4 ports I use to connect the
> switch to the router [...]Any one of the four router LAN ports should be fine for the
connection to any one of the switch ports.> [...] and that it's okay to be using the other 3 ports for other
> devices simultaneouslyYup.
Now it's my turn. _I_ assume that these devices have some kind of
LED port-status indicators, which only one of us can see. Care to share
the enlightenment? Have you tried swapping cables?
> connections are wrong?Your expectations seem ok. If a router LAN port works with an
individual device, then it should work with a network switch. A bad
switch could cause problems for a device which is connected to the
switch. I can't see your "my connections". But some of this sounds
strangely familiar.
