OneJoe2
Jun 13, 2020Tutor
Should the R8000 UI see devices connected via a GS308 switch?
In the supplied user interface, on the Basic tab, "attached devices/wired devices" area, should I be seeing any info at all (like status, IP, MAC address) for devices on a connected GS308v2 or is ...
- Jun 13, 2020
You should see all devices connected to the switch
OneJoe2
Jun 13, 2020Tutor
Thank you!
michaelkenward
Jun 14, 2020Guru - Experienced User
As long as the switch as after the router.
- OneJoe2Jun 15, 2020TutorAfter the router .. yes. Thanks!
- OneJoe2Jun 16, 2020Tutor
cable modem -> R8000 router -> GS308 switch -> devices
This is considered after the router, yes?
I replaced the switch with a new GS308v3, changed to new cables and still can't "see" the devices on the switch.
All devices work fine if I connect them directly to the router but not on the (new) switch.
I assume it doesn't matter which of the 4 ports I use to connect the switch to the router and that it's okay to be using the other 3 ports for other devices simultaneously
And that it doesn't matter which port on the switch that I use to connect to the router?
Either my expectatons are wrong, the router is broken or my connections are wrong?
- antinodeJun 16, 2020Guru
I don't know what "before" or "after" a router means. It's an
ambiguous nonsense concept. I do know what the WAN side and the LAN
side of a router mean.If a port on your switch is connected to a LAN Ethernet port on the
router, then things should work properly.Now, let's move on to actual facts.
> [...] still can't "see" the devices on the switch.
What are these (unspecified) "devices"?
Is your complaint that these (mystery) devices do not _work_ if you
connect them to the switch, or that they work, but don't appear in an
Attached Devices report on the router, or what, exactly?> I assume it doesn't matter which of the 4 ports I use to connect the
> switch to the router [...]Any one of the four router LAN ports should be fine for the
connection to any one of the switch ports.> [...] and that it's okay to be using the other 3 ports for other
> devices simultaneouslyYup.
Now it's my turn. _I_ assume that these devices have some kind of
LED port-status indicators, which only one of us can see. Care to share
the enlightenment? Have you tried swapping cables?
> connections are wrong?Your expectations seem ok. If a router LAN port works with an
individual device, then it should work with a network switch. A bad
switch could cause problems for a device which is connected to the
switch. I can't see your "my connections". But some of this sounds
strangely familiar.- OneJoe2Jun 17, 2020Tutor
antinode wrote:. But some of this sounds
strangely familiar.https://community.netgear.com/t5/x/x/m-p/1927787
Good memory. I know it's not easy being the sensei and having a never-ending stream of idiotic people appear here to ask the same idiotic questions but I had to bail on that thread.
- michaelkenwardJun 17, 2020Guru - Experienced User
That's right. After all, you are asking the router to tell you what is connected to it.
Out of interest, but possibly relevant, what is this cable modem? Make and model?
So, none of the devices that you add to the network through the new switch will work? Is that also the case for the old switch? Invisible and not working?
I ask because earlier on it was the invisibility that troubled you. Now it is that and the fact that they also don't work.
- antinodeJun 17, 2020Guru
> That's right. [...]
It's "right" if you start ar your ISP, and count toward your own
computer. Obviously, it's the opposite if you start at your own
computer, and count toward your ISP. I'm unaware of any industry
standard, or any reasonable rationale, which says which way you should
view your network. (But I'm always open to enlightenment.) Hence:> I don't know what "before" or "after" a router means. It's an
> side of a router mean.Think about it. If you can.
