brfr125's avatar
brfr125
Since installing latest firmware can't disable WPS PIN in R7000
I installed the latest firmware for a R7000 and did a reset. Since then I cannot turn off the WPS PIN feature. I uncheck the box and apply and the router keeps checking the enable WPS PIN feature. Is...
