Flash7Gordon
Sep 23, 2019Guide
Since latest Nighthawk release shared usb drive not working
Hi, My usb sharing on the nighthawk has always been very reliable. We have lots of pc's, macs and whatever and it always worked very well. With the mac I would mount smb://readyshare and it alwa...
- Sep 24, 2019
Don't have my R7000 or R8000 connected anymore, went to a different vendor once they dropped DLNA that I use from those models.
I am suggesting that they no longer SHARE the USB drive, that is all?
It is KNOWN and documented that they have removed 'function' from the USB drive related to how the f/w will work with it.
From the README on the last F/W
Please note that starting with this firmware release (V1.0.9.88), iTunesServer, Kwilt Photosharing, Time Machine Backup, TiVo support for media sharing, and the Downloader feature (which was in beta) are no longer supported. If you want to continue using these features, do not update the firmware.
New Features and Enhancements:
- Supports NETGEAR Armor
- Removes the following features: iTunes Server, Downloader, Time Machine, Kwilt, TiVo, and DLNA
Here is what you said:
We have lots of pc's, macs and whatever and it always worked very well. With the mac I would mount smb://readyshare and it always worked. But since I did that nighthawk software upgrade encouraged around the beginning of September 2019, can't get the nighthawk usb drive on my mac and it doesn't mount on my windows machines either.
Not knowing what it is that you used it with or how? I don't use MAC's, but Windows has some similar commands, like NET USE. I suspect (can't verify) that DLNA also included the Samba Server, hence your problem.
My suggestion to go back in F/W still holds, or get a router from a vendor that still supports Samba/DLNA.
IrvSp
Sep 24, 2019Master
You might be using an R8000 or R7000. Check the f/w version, and then go to Support, put you router model in and then hit enter and select downloads. Click on your f/w versions (might need to open prior versions to see it) and then READ the RELEASE NOTES. If DLNA has been removed, that is the reason.
Only recourse is to backlevel firmware than still had DLNA in it (and set AUTO-UPDATE to disabled).
