JohnnyWB
Nov 20, 2015Tutor
Since the last firmware update, I am having all kinds of issues with my NightHawk AC1750
I am beginning to wonder what in the round world is going on with this thing. Last update brought a whole ton of problems with it: Can't stay connected to the internet as it drops the ocnnection. B...
- Nov 21, 2015
Factory reset is only needed when you are having problems. I always backup my configuration file first. Then test if there is a problem when not reload the configuration agian. I Reset is neede when you downgrade from higher firmware with new options. Please make a support ticket it can be a bug.
TheEther
Nov 20, 2015Guru
Perform a factory reset. It's strongly recommended after every firmware update.
alien433
Nov 21, 2015Guide
- JohnnyWBNov 21, 2015Tutor
Allen, before I do that, I would like to find out the reasoning behind ellen's adivce. Not sure if there is a hidden gem/kernel there none of us are aware of or what. Admitedly I am a huge noob with electronics, even after all this time since the "Trash 80 Days" of Tandy home computing.
