JohnnyWB
Nov 20, 2015Tutor
Since the last firmware update, I am having all kinds of issues with my NightHawk AC1750
I am beginning to wonder what in the round world is going on with this thing. Last update brought a whole ton of problems with it: Can't stay connected to the internet as it drops the ocnnection. B...
- Nov 21, 2015
Factory reset is only needed when you are having problems. I always backup my configuration file first. Then test if there is a problem when not reload the configuration agian. I Reset is neede when you downgrade from higher firmware with new options. Please make a support ticket it can be a bug.
TheEther
Nov 21, 2015Guru
The reason a factory reset is recommended after updating firmware is that the old configuration settings could be incompatible. This can be true for updates to newer as well as older firmware versions.
A reset will erase the configuration. The currently installed firmware will remain intact.
Do not restore the configuration from a backup file. The file could be incompatible. Instead, manually reconfigure each setting using either the desktop Genie or the web interface on the router.
- alien433Nov 21, 2015Guide
Reset is not needed, i'm Syste technical for more than 20 years. Please contact support
- JohnnyWBNov 21, 2015Tutor
I am going to put in a tech support ticket and see what they can come up with. Thanks to the both of you. I appreciate it.
- netwrksNov 21, 2015Master
Anyone who does not reset to factory default on these router after a firmware upgrade is asking for problems. Rule of thumb. Upgrade firmware. Then reset to fsctory default. Reconfig from scratch Always..
