JohnnyWB
Nov 20, 2015Tutor
Since the last firmware update, I am having all kinds of issues with my NightHawk AC1750
I am beginning to wonder what in the round world is going on with this thing. Last update brought a whole ton of problems with it: Can't stay connected to the internet as it drops the ocnnection. B...
- Nov 21, 2015
Factory reset is only needed when you are having problems. I always backup my configuration file first. Then test if there is a problem when not reload the configuration agian. I Reset is neede when you downgrade from higher firmware with new options. Please make a support ticket it can be a bug.
TheEther
Nov 21, 2015Guru
The reason a factory reset is recommended after updating firmware is that the old configuration settings could be incompatible. This can be true for updates to newer as well as older firmware versions.
A reset will erase the configuration. The currently installed firmware will remain intact.
Do not restore the configuration from a backup file. The file could be incompatible. Instead, manually reconfigure each setting using either the desktop Genie or the web interface on the router.
alien433
Nov 21, 2015Guide
Reset is not needed, i'm Syste technical for more than 20 years. Please contact support
- JohnnyWBNov 21, 2015Tutor
I am going to put in a tech support ticket and see what they can come up with. Thanks to the both of you. I appreciate it.
- netwrksNov 21, 2015Master
Anyone who does not reset to factory default on these router after a firmware upgrade is asking for problems. Rule of thumb. Upgrade firmware. Then reset to fsctory default. Reconfig from scratch Always..
