JohnnyWB
Nov 20, 2015Tutor
Since the last firmware update, I am having all kinds of issues with my NightHawk AC1750
I am beginning to wonder what in the round world is going on with this thing. Last update brought a whole ton of problems with it: Can't stay connected to the internet as it drops the ocnnection. B...
- Nov 21, 2015
Factory reset is only needed when you are having problems. I always backup my configuration file first. Then test if there is a problem when not reload the configuration agian. I Reset is neede when you downgrade from higher firmware with new options. Please make a support ticket it can be a bug.
alien433
Nov 21, 2015Guide
Its the best thing to contact support. Everythime reset after firmware update is not needed. I had several routers and not needed to do a reset.
TheEther
Nov 21, 2015Guru
I've worked in the networking industry for more than 20 years, doing software development for much of it. I've seen my fair share of backwards compatibility configuration bugs.
Think of a reset as preventative medicine. It can avoid mysterious ailments. Best of all, this medicine is free.
I can almost guarantee you that support will ask you to reset your router, so you may as well save yourself the trouble of having them tell you.
