JohnnyWB
Nov 20, 2015Tutor
Since the last firmware update, I am having all kinds of issues with my NightHawk AC1750
I am beginning to wonder what in the round world is going on with this thing. Last update brought a whole ton of problems with it: Can't stay connected to the internet as it drops the ocnnection. B...
- Nov 21, 2015
Factory reset is only needed when you are having problems. I always backup my configuration file first. Then test if there is a problem when not reload the configuration agian. I Reset is neede when you downgrade from higher firmware with new options. Please make a support ticket it can be a bug.
JohnnyWB
Nov 21, 2015Tutor
10-4 and thanks to all of you. I will first do a reset, should that not cure the issue, I will then put ina ticket for support help. If nothing else helps, I will simply return the defective unit to the place of purchase. I up graded from an N600 to this AC1750 for the technology and speed upgrade but so far this 1750 has been a big disappointment for me. While my 600 was as slow as Methuselah, it was very dependable and not full of problems.
Again, thanks all, I appreciate your comments and suggestions.
