fdhsf
Jul 27, 2018Aspirant
Slow download speeds
Hello, I have a r7000 router for my 1 gbps connection but I can´t get the full speed in wired in my company router I have full speed in speedtest.net I usually have 200 to 500 mbps I tried to downgra...
- Jul 27, 2018
Yes my company router is in bridge mode and r7000 in router mode.
fdhsf
I can´t see any higher speed than 450 mbps with all disabled, qos, trafic meter and circle.
myersw
Jul 27, 2018Master
Probably time for an upgrade.
One of the things folks overlook when upgrading Internet service is that the existing equipment might not be up to the task. I would think that the r7800 called out in previous message would handle it. Install Voxel firmware and should be good to go. Just make sure that what you get you can return if it turns out to not be up to the task.
