fdhsf
Jul 27, 2018Aspirant
Slow download speeds
Hello, I have a r7000 router for my 1 gbps connection but I can´t get the full speed in wired in my company router I have full speed in speedtest.net I usually have 200 to 500 mbps I tried to downgra...
- Jul 27, 2018
Yes my company router is in bridge mode and r7000 in router mode.
Jul 27, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem. Then you can use the NG router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the NG router.
fdhsf wrote:
I have the last firmware V1.0.9.34_10.2.36 and I have hfc my isp router I think is a rebranded by my isp the company named saecom or sagemcom and the model is a F@ST 3686 AC. With company router I can get full speed. Thanks to all for help.
fdhsf
