Double0
Apr 08, 2022Aspirant
slow ethernet connection r7000
I recently had 1Gbps fiber ethernet installed and I get that speed when my computer is attached directly to the cable company's box. But when I plug my computer into my router (R7000 Nighthawk) it d...
Double0
Thanks FURREYe38 for the details.
Firmware is V1.0.11.134_10.2.119 I just downloaded it today.
The ONT is iPhontonix Model 7477G
I didn't know cat5 doesn't support 1Gbps, I'll have to get a cat6 wire.
Apr 09, 2022Guru - Experienced User
From what I could find on that ONT, it has its own integrated router. It causes a double nat. (not necessarily your slow downs through)
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
to fix your slow downs, make sure the r7000 has qos, access control, traffic monitoring, and parental controls all disabled. If you've ever had them enabled, factory reset the router and start back at stock. during the install DO NOT enable those features. the r7000 is a 9 year old router and when those features are enabled, it disables ctf (cut through forwarding) which is needed to hit gigabit speeds.
- Double0Apr 09, 2022Aspirant
plemans, thanks for the reply, I do appreciate the time you put into this.
My iPhotonix does not have a router or it was disabled, so I do not think there is any Double NAT problem.
On my router all of the items you mentioned are disabled and I did start off with a factory reset. The access control does not show on my router's dialogue so I assume it is disabled.
I did change to cat6 cables so that's not an issue now.
But I still only get 200Mbps. I'll have the provider check again to see if it is their issue, and maybe I need to upgrade the router.
- FURRYe38Apr 09, 2022Guru - Experienced User
Do you get to spec speed with a wired PC directly connnected to the ONT?
Has a factory reset and setup from scratch been performed since last FW upate? Be sure to not enable Armor, Circle. QoS or Traffic Meter.
Test soon as the setup wizard completes.- Double0Apr 09, 2022Aspirant
FURRYe38, thanks. I did get spec speed when the PC was wired to the ONT when they installed it, but today the speed is down when I wired direct.. So I contacted them again to send a third Tech out.
I did perform the "factory reset" after the FW update. All of the accessories are disabled.
At this point I do believe there is a problem with the ONT or down the wire..
