generationbk
May 11, 2020Aspirant
Slow Ethernet Speed on Nighthawk X6S R8000P (cable works ok, wifi works ok)
As the title says. I just replaced my standard Verizion router with a new NetGear Nighthawk router. With the Verizon router, ethernet speed was great. Now it's barely hitting 5.49 Mbps downlo...
- May 12, 2020
Hi,
Thanks for reaching out.
I ended up finding the solution by disabling the xFast LAN program that was automatically downloaded with my Asrock Motherboard. That upped my speed by ~10x, so it's all fixed.
Just to answer your question, I am using Fios.
Take care.
May 12, 2020Guru - Experienced User
What is the router connect to? What device?
Are you using verizon fios?
https://kb.netgear.com/23977/Will-my-NETGEAR-router-work-with-Verizon-FiOS
- generationbkMay 12, 2020Aspirant
Hi,
Take care.
